Hello
After recently replacing the clutch, clutch plate & clutch slave cylinder on my 2002 MK5 Fiesta 1.4 16V petrol, the car worked fine for a few weeks. However, I have now started experiencing clutch slip with high revs but no movement, as well as juddering upon acceleration.
I have double-checked the installation; but I'm unsure of the exact cause. Could it be a problem with the clutch components or something else like the flywheel or hydraulic system? The clutch seems to disengage too early, and there's a noticeable delay in power transfer.
I've also noticed a strange noise when the car is in gear and the clutch is engaged. I have checked https://www.fordfiesta.org/thr…sion-clutch-problem.7865/mongodb guide for reference .
Any advice would be greatly appreciated & I'm open to suggestions for further diagnostics or repairs.
Thanks in advance!
