Gude
Do you have a Checklamp ( a bulb with a bit of wire) ? Ground (31) Battery on one end of the wire, the other side of the wire on coil 15, is the bulb on ? Your problem is maybe the switch in the distributor. Do you have a picture from inside without the cap?
on your coil are 3 connection points: in the middle is 4 ignition cable to distribute cap, on the side is 15 (Battery positive) and the last one on the other side is 1 ( Battery negative switched from distributor)
