Hallo!
strange 4-door 17M RS with V6 1.8L...
P7B 32F 17M RS, Was ist das?
no, the 17m rs was avaiable with the 1,8,2.0,2.3 and 2.6 V6-engines.
the 1.8 is very rare, btw.
yes, I know too,
but this is 32F body with NY Motor... and that strange type plate... -
not all p7 were build in cologne.
maybe this is an export version. or the car had an accident and the front end had to be repaird...normally the typing on the type plate is from the back,isnt it? you can get new type plates by ford...
is the engine original? -
is the engine original?of course. I mean- strange RS complektation.
all numbers are original, all plates are right.
Alternative idea (basic color is green): -
in sale photos.
what's the problem? the RS was also available as 4-door sedan, the car was build in plant antwerpen in belgium
got a vinyl-top, so no police car.from wich state is it, finland?
not ervery RS got RS-stripes on the side.
other idea: engine has been replaced...
and, ford made a lot of specials, to attract his cars for the sellers...
i remember in 1987 my dad had a 20m RS 2600 4-door in white, interior black. no vinyl roof, no RS-stripes,no RS-wheels, all original, first owner.
this car have 3 type plate: two normal and one absend in manual :)
& have no docs, but, now, we thinking about take or not to take this :)
if this car are frankenstain, thinking to use it for spares, if original - possibly try to find new owner :) -
may be. may be.
this car in Weissrussia, ~1200km from me & Suomi :)
not far away... -
whats the chassis number?
G = manufactured and assembled by Ford of Germany
A = in Genk (Belgium)32 = 17M 4-door sedan
L = Build 1971
D = March91108 = sequence number
RS - 1800 V6 never official in Germany the smallest was a 2000 in Germany!
I got all the Factorypapers of the hole P7 RS series here for over over twenty years and there´s no 1800 v6 engine known.
türlich gabs den 1800er v6 in deutschland...???
Hau nich so aufe Kacke.
Nannte sich 17M 1800S
and allready an RS Type has to be black inside and this Headliner is white, all of the RS Fakes own this Detail !
you maybe can look at the part no. of the steering gear assy.
The "standard" models had a 19,9 : 1 Ratio, part no. 0439938
The "RS" models had a 16,0 : 1 Ratio, part no. 0439841Changing the gear assey is not only a one hour job, so i think most of the fakers don't change this gear assey, maybe also they don't know that this is different.
Also can look at the Bracket for the long range lamps.
Some Brackets was connected to the body by screws, but most spot-welded.
If they are spot-welded, i think 99% its originalIf its a fake anyway, than a real real well implemented
17 m 1800 s ist aber kein RS - sondern eine billiger 17m aber eben schon mit dem kleinsten v6 der Welt
und dieser " RS " ist ein Fake, oder sollte sich einer die Mühe gemacht haben extra nen weißen Himmel einzubauen - wohl kaum
ein RS ist schwarz von innen und den Himmel vergessen die Pfuscher immer.
