I am searching a 16v cylinder head for a 4 cilinder block.
Is it possible to adapt one? Is there any car that used thios kind of head?
I would like to see photos or a project.
The idea is to use it normally aspirated.
16v Cylinder head for Taunus
- Taunus2.8
Which block du you have? I think the 2.3 Block is a little different from the "block de cologne". But I am not shure about that. Maybe it is only a minor difference.
So if there is no or only a minor differnce you could use a Cosworth Head. 16 valves, made for a turbocharger but also used without could be a good match for your block. A pretry expensive one too.
Sierra Cosworth
Escort Cosworth, just google for cosworh. The 2.0 turbo is based on the german 4 Banger -
Original von Kowalski
Which block du you have? I think the 2.3 Block is a little different from the "block de cologne". But I am not shure about that. Maybe it is only a minor difference.So if there is no or only a minor differnce you could use a Cosworth Head. 16 valves, made for a turbocharger but also used without could be a good match for your block. A pretry expensive one too.
Sierra Cosworth
Escort Cosworth, just google for cosworh. The 2.0 turbo is based on the german 4 BangerThanks! I will search for the escort cosworth and cologne, becasue sierra cosworth doesnt fit.
I searched for b234f cylinder head, only one guy put it on.
But he has nop contact in hi page. :?
I will google. -
If the Sierra Cosworth does not fit the Escort won't fit either as they have got basically the same engine.
you might also not find anything interesting while searching for "cologne". By cologne I just meant the german Block which is the basis of the european fourbanger. -
The only that fits its the volvo b234f i think.
Thanks -
Hi!
Did you check out http://www.burton-power.com?
They have all tuning parts for ford engines.Nice car!
